Uncle Birchy
Maybe put an Ice pack on it reduce the swelling.No clue.
doc has me on plavix. So bruising is easy
Already didMaybe put an Ice pack on it reduce the swelling.
FACT!Patience.
I'm running low on patience of half steppers and malingerers who come to Menomonie and get our best loads while I run around Chicago more than anyone should ever have to.
Then they play sick or whine and cry about driving 500 miles in a straight line on a weekend when they're paid more to do so.
I hope Walmart starts hammering accountability on lazy asses who can't drop and hook dry vans.
Honestly zero respect for these people. And its only going to get worse.
Theres a real reason open deck drivers and everyone else looks down on van drivers. A REAL reason.
It's because they've earned it.
It's much easier now than it used to be with the advent of air ride suspension. It used to be where you'd wheel up with 24.5's expecting to just slide under a box and you get to it and it's 6" lower than the lowest part of your frame. They guy that dropped it had 10.00X20's on his pegleg Shaker. So you stand there in sub 0 weather trying to crank up the frozen landing gear.Patience.
I always leave the legs an inch or two up when I drop one.It's much easier now than it used to be with the advent of air ride suspension. It used to be where you'd wheel up with 24.5's expecting to just slide under a box and you get to it and it's 6" lower than the lowest part of your frame. They guy that dropped it had 10.00X20's on his pegleg Shaker. So you stand there in sub 0 weather trying to crank up the frozen landing gear.
Today, you blow the bags and get under just about anything left by the previous steering wheel holder. Or, maybe you can dump your bags if it's too low and just get the frame rails under the front of it, then inflate them to get the landing gear down a little lower. Yeah, you get grease on the frame rail tips, but it wipes off with a few paper towels from that stock in the cab.
And if you are running Low Profile 22.5's, the next guy with regular 22.5's or 24.5's will have a heck of time getting under it without slamming the pin. Set it on the ground, blow your bags and gently slide out from under it.I always leave the legs an inch or two up when I drop one.
Reason is I always hated one dropped too high and having to crank it down.
Also on one that's been sitting along time or a bad crank it's nice to use the bags lift it off the ground then start cranking.
Back at Dejnos I started out with an International Daycab but the Peterbilts left the trailers higher which often meant I hadda crank loaded ones down to me.And if you are running Low Profile 22.5's, the next guy with regular 22.5's or 24.5's will have a heck of time getting under it without slamming the pin. Set it on the ground, blow your bags and gently slide out from under it.
I know what @Electric Chicken goes through pulling the cans. I used to load seagoing tanks with fuel for the Islands. We had 3 trucks all with different sized tires on them. Then you had the island hoppers with, who know what on them. I'd rather have to lower a trailer/chassis than raise it.
Yes and you "deviated" off of that with your rant about Dry Van Wheel holders.Has anyone checked the title of the thread and topic lately?
Been ages since my folks made me listen to the Hooked On Phonics tapesSure! It's all about the patience that we run out of due to the stupidity of others and the forces of Mama Nature.
Can'tcha read?![]()
I quit drinking 5 years ago.Yes and you "deviated" off of that with your rant about Dry Van Wheel holders.
Besides does anything stay on topic around here more than a page or two anyways..
It's Independence Day so crack afew beers "lighten up" abit and enjoy the holiday weekend.
I honestly thought I put my last comment in the “check in often thread”,Has anyone checked the title of the thread and topic lately?
Meh. I made it work.I honestly thought I put my last comment in the “check in often thread”,
so if you want, feel free to move it.
Anytime it's not already perfect is annoying but yeah I'll take cranking down over cranking up any day.And if you are running Low Profile 22.5's, the next guy with regular 22.5's or 24.5's will have a heck of time getting under it without slamming the pin. Set it on the ground, blow your bags and gently slide out from under it.
The drivers doin that is bad enuff. What really gets me is that they keep gettin away with itI lost my patience to deal with other company drivers lack of care for equipment by buying my own. Screw that. Only one I have to blame for anything is me.
That's dangerous territory. Take a lesson from @Uncle Birchy and pilfer 500 or 600 napkins from Wendy's when you use your coupon.Paper towels. Forgot to restock, half a roll left.
