Caterpillar (CAT) ACERT intake valve actuator wiring replacement
Tim
U.S.Constitution
Premium
@Tim submitted a new resource:
Caterpillar (CAT) ACERT intake valve actuator wiring replacement - 45 minutes from start to finish
If you have a Acert CAT odds are your gonna have a wiring issue with the IVA's at some point in time. The cause is oil getting into the wiring plug thus causing a LOW VOLTAGE to the actuator itself.
Its a easy fix with a replacement wiring harness from CAT.
First thing after removing the valve cover is to know what wire is what.
In this case I've done pulled the wire off in question. The IVA is the round yellow thing. The one in the center is for the CAT brake.
View attachment 25351 ...
Read more about this resource...
ai236.photobucket.com_albums_ff53_anythingracing_IMG_0475_zps49e16a03.jpg ai236.photobucket.com_albums_ff53_anythingracing_IMG_0476_zpsbbdb3b6c.jpg ai236.photobucket.com_albums_ff53_anythingracing_IMG_0477_zps6b246bd1.jpg
DubbleD
Color Commentator
A wise man once told me Cummins had a real good design because the electrical parts are on the OUTSIDE where they won't be bathing in synthetic lubricants.
Now, I would agree with that ....BUT....
A Ziplock Baggie would be preferable to the shrinking boots that protect the connections from elements.
Tim
U.S.Constitution
Premium
That wise man was a idiot! :D
The original connecters did not come with a boot. Thats the problem, it soon lets oil into the harness and for what ever the reason current stops passing thru.
If you go back and look at the first 2 pic you'll see the difference in the old one and the new one.
DubbleD
Color Commentator
You calling one of the smartest guys I know in anything motor....an idiot!?
You're an idiot!
